Jul 07, 2012Guru - Experienced User
ReadyDLNA OS Partition Usage
I just noticed that ReadyDLNA's database and artwork cache are stored on the OS partition (/var/cache/minidlna). On my system that is about 600 MB of the limited OS partition space :shock: Is th...
mdgm-ntgr
Apr 23, 2013NETGEAR Employee Retired
Here are the add-ons to Toggle the ReadyDLNA CacheDir for x86 and SPARC:
For ARM currently you would still need to do it manually. If you need help manually updating the sqlite3 database entering the command Skywalker suggested I could assist with that.
Skywalker wrote:
x86: http://www.readynas.com/download/addons/x86/4.2/Toggle_ReadyDLNA_CacheDir_1.0-x86.bin
SPARC: http://www.readynas.com/download/addons/4.1/Toggle_ReadyDLNA_CacheDir_1.0.bin
