CarlEdman
May 08, 2014Luminary
ReadyDLNA/MiniDLNA/UPNPAV/ReadyMedia Problems
I am running the current version--reported as 1.1.0--of the boxed-in DLNA server which comes with RAIDiator 4.2.26 on my ReadyNAS Ultra 6 Plus. Most files stream fine to a variety of UPNP devices, bu...
CarlEdman
Thank you, StephenB, but I doubt that is it. All the files, both the thousands that work and the dozens that don't, are h264 video (generated by x264), AAC audio, and usually mp4s subtitles. There are no non-ASCII characters in the file names.
Below are two example mediainfo outputs of the backup of two movies for which I made backups from my DVDs/Blu-rays. Both generate consistently generate the above error in readydlna.
General
Complete name : Y:\Movies\Thriller\Constantine (2005) HD.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 3.01 GiB
Duration : 2h 0mn
Overall bit rate mode : Variable
Overall bit rate : 3 567 Kbps
Movie name : Constantine
Genre : Thriller
ContentType : Short Film
Description : In a world ruled largely by logic, an eccentric private detective with a taste for the supernatural investigates an apparent suicide in this thriller based on the comic book "Hellblazer." Cast: Keanu Reeves, Rachel Weisz, Shia LaBeouf, Djimon Hounsou, Ma
Recorded date : 2005
Encoded date : UTC 2014-04-09 13:18:21
Tagged date : UTC 2014-04-09 13:20:14
Writing application : MakeMP4 3.7 on Wednesday, April 09, 2014, at 09:19:02
Cover : Yes
Comment : Rating: R;Genres: Action & Adventure, Comic Books and Superheroes, Supernatural Thrillers, Action Thrillers, Blu-ray;This movie is: Dark;Format: DVD and Blu-ray
LongDescription : In a world ruled largely by logic, an eccentric private detective with a taste for the supernatural investigates an apparent suicide in this thriller based on the comic book "Hellblazer." Cast: Keanu Reeves, Rachel Weisz, Shia LaBeouf, Djimon Hounsou, Max Baker, Pruitt Taylor Vince, Gavin Rossdale, Tilda Swinton, Peter Stormare. Director: Francis Lawrence.
HDVideo : Yes
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 2h 0mn
Bit rate : 2 719 Kbps
Maximum bit rate : 21.6 Mbps
Width : 1 920 pixels
Height : 792 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.075
Stream size : 2.29 GiB (76%)
Title : Constantine () HD T01.out.264:lang=eng:fps=23.976023976023978 - Imported with GPAC 0.5.0-rev4065
Writing library : x264 core 142 r2409 d6b4e63
Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Tagged date : UTC 2014-04-09 13:18:47
Audio #1
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 2h 0mn
Bit rate mode : Variable
Bit rate : 327 Kbps
Maximum bit rate : 414 Kbps
Channel(s) : 2 channels
Channel(s)_Original : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 283 MiB (9%)
Language : English
Encoded date : UTC 2014-04-09 13:18:38
Audio #2
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 2h 0mn
Bit rate : 96.0 Kbps
Maximum bit rate : 137 Kbps
Channel positions : Front: L R
Stream size : 81.5 MiB (3%)
Language : English
Encoded date : UTC 2014-04-09 13:18:41
Audio #3
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 2h 0mn
Bit rate : 93.9 Kbps
Maximum bit rate : 144 Kbps
Stream size : 81.2 MiB (3%)
Language : English
Encoded date : UTC 2014-04-09 13:18:43
Audio #4
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 2h 0mn
Bit rate : 87.6 Kbps
Maximum bit rate : 98.8 Kbps
Stream size : 75.7 MiB (2%)
Language : English
Encoded date : UTC 2014-04-09 13:18:44
Text #1
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 6 066 bps
Maximum bit rate : 94.2 Kbps
Stream size : 5.24 MiB (0%)
Title : Constantine () HD T07.idx:lang=eng - Imported with GPAC 0.5.0-rev4065
Language : English
Encoded date : UTC 2014-04-09 13:18:46
Text #2
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 11.6 Kbps
Maximum bit rate : 111 Kbps
Stream size : 10.0 MiB (0%)
Title : Constantine () HD T08.idx:lang=eng - Imported with GPAC 0.5.0-rev4065
Language : English
Text #3
Format : mp4s
Codec ID : E0
Duration : 1h 59mn
Bit rate : 5 066 bps
Maximum bit rate : 4 209 Mbps
Stream size : 4.34 MiB (0%)
Title : Constantine () HD T09.idx:lang=jpn - Imported with GPAC 0.5.0-rev4065
Language : Japanese
Text #4
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 4 791 bps
Maximum bit rate : 90.5 Kbps
Stream size : 4.14 MiB (0%)
Title : Constantine () HD T10.idx:lang=fra - Imported with GPAC 0.5.0-rev4065
Language : French
Text #5
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 7 261 bps
Maximum bit rate : 107 Kbps
Stream size : 6.27 MiB (0%)
Title : Constantine () HD T11.idx:lang=deu - Imported with GPAC 0.5.0-rev4065
Language : German
Text #6
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 6 060 bps
Maximum bit rate : 91.0 Kbps
Stream size : 5.23 MiB (0%)
Title : Constantine () HD T12.idx:lang=ita - Imported with GPAC 0.5.0-rev4065
Language : Italian
Text #7
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 4 878 bps
Maximum bit rate : 106 Kbps
Stream size : 4.21 MiB (0%)
Title : Constantine () HD T13.idx:lang=spa - Imported with GPAC 0.5.0-rev4065
Language : Spanish
Text #8
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 4 979 bps
Maximum bit rate : 95.2 Kbps
Stream size : 4.30 MiB (0%)
Title : Constantine () HD T14.idx:lang=nld - Imported with GPAC 0.5.0-rev4065
Language : Dutch
Text #9
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 5 411 bps
Maximum bit rate : 101 Kbps
Stream size : 4.67 MiB (0%)
Title : Constantine () HD T15.idx:lang=spa - Imported with GPAC 0.5.0-rev4065
Language : Spanish
Text #10
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 5 150 bps
Maximum bit rate : 102 Kbps
Stream size : 4.45 MiB (0%)
Title : Constantine () HD T16.idx:lang=dan - Imported with GPAC 0.5.0-rev4065
Language : Danish
Text #11
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 4 854 bps
Maximum bit rate : 90.4 Kbps
Stream size : 4.19 MiB (0%)
Title : Constantine () HD T17.idx:lang=fin - Imported with GPAC 0.5.0-rev4065
Language : Finnish
Encoded date : UTC 2014-04-09 13:18:47
Text #12
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 5 240 bps
Maximum bit rate : 94.3 Kbps
Stream size : 4.53 MiB (0%)
Title : Constantine () HD T18.idx:lang=nor - Imported with GPAC 0.5.0-rev4065
Language : Norwegian
Text #13
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 5 338 bps
Maximum bit rate : 98.9 Kbps
Stream size : 4.61 MiB (0%)
Title : Constantine () HD T19.idx:lang=por - Imported with GPAC 0.5.0-rev4065
Language : Portuguese
Text #14
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 4 670 bps
Maximum bit rate : 95.1 Kbps
Stream size : 4.03 MiB (0%)
Title : Constantine () HD T20.idx:lang=swe - Imported with GPAC 0.5.0-rev4065
Language : Swedish
Text #15
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 71 bps
Maximum bit rate : 81.3 Kbps
Stream size : 62.5 KiB (0%)
Title : Constantine () HD T21.idx:lang=fra - Imported with GPAC 0.5.0-rev4065
Language : French
Text #16
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 93 bps
Maximum bit rate : 105 Kbps
Stream size : 82.1 KiB (0%)
Title : Constantine () HD T22.idx:lang=deu - Imported with GPAC 0.5.0-rev4065
Language : German
Text #17
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 91 bps
Maximum bit rate : 94.8 Kbps
Stream size : 80.2 KiB (0%)
Title : Constantine () HD T23.idx:lang=ita - Imported with GPAC 0.5.0-rev4065
Language : Italian
Text #18
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 103 bps
Stream size : 90.3 KiB (0%)
Title : Constantine () HD T24.idx:lang=spa - Imported with GPAC 0.5.0-rev4065
Language : Spanish
Text #19
Format : mp4s
Codec ID : E0
Duration : 1h 59mn
Bit rate : 11.7 Kbps
Stream size : 10.1 MiB (0%)
Title : Constantine () HD T25.idx:lang=jpn - Imported with GPAC 0.5.0-rev4065
Language : Japanese
Text #20
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 11.1 Kbps
Maximum bit rate : 4 207 Mbps
Stream size : 9.57 MiB (0%)
Title : Constantine () HD T26.idx:lang=jpn - Imported with GPAC 0.5.0-rev4065
Language : Japanese
Text #21
Format : mp4s
Codec ID : E0
Duration : 1h 59mn
Bit rate : 3 440 bps
Maximum bit rate : 4 210 Mbps
Stream size : 2.94 MiB (0%)
Title : Constantine () HD T27.idx:lang=jpn - Imported with GPAC 0.5.0-rev4065
Language : Japanese
Text #22
Format : mp4s
Codec ID : E0
Duration : 1h 53mn
Bit rate : 27.2 Kbps
Maximum bit rate : 4 250 Mbps
Stream size : 22.2 MiB (1%)
Title : Constantine () HD T28.idx:lang=jpn - Imported with GPAC 0.5.0-rev4065
Language : Japanese
Text #23
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 9 384 bps
Maximum bit rate : 115 Kbps
Stream size : 8.10 MiB (0%)
Title : Constantine () HD T29.idx:lang=fra - Imported with GPAC 0.5.0-rev4065
Language : French
Text #24
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 11.2 Kbps
Maximum bit rate : 108 Kbps
Stream size : 9.71 MiB (0%)
Title : Constantine () HD T30.idx:lang=deu - Imported with GPAC 0.5.0-rev4065
Language : German
Text #25
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 10.9 Kbps
Stream size : 9.45 MiB (0%)
Title : Constantine () HD T31.idx:lang=ita - Imported with GPAC 0.5.0-rev4065
Language : Italian
Text #26
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 9 739 bps
Stream size : 8.41 MiB (0%)
Title : Constantine () HD T32.idx:lang=spa - Imported with GPAC 0.5.0-rev4065
Language : Spanish
Text #27
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 10.4 Kbps
Stream size : 9.00 MiB (0%)
Title : Constantine () HD T33.idx:lang=nld - Imported with GPAC 0.5.0-rev4065
Language : Dutch
Text #28
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 9 246 bps
Stream size : 7.99 MiB (0%)
Title : Constantine () HD T34.idx:lang=dan - Imported with GPAC 0.5.0-rev4065
Language : Danish
Text #29
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 8 915 bps
Stream size : 7.70 MiB (0%)
Title : Constantine () HD T35.idx:lang=fin - Imported with GPAC 0.5.0-rev4065
Language : Finnish
Text #30
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 9 840 bps
Maximum bit rate : 104 Kbps
Stream size : 8.50 MiB (0%)
Title : Constantine () HD T36.idx:lang=nor - Imported with GPAC 0.5.0-rev4065
Text #31
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 10.7 Kbps
Stream size : 9.26 MiB (0%)
Title : Constantine () HD T37.idx:lang=por - Imported with GPAC 0.5.0-rev4065
Text #32
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 9 192 bps
Maximum bit rate : 93.2 Kbps
Stream size : 7.94 MiB (0%)
Title : Constantine () HD T38.idx:lang=swe - Imported with GPAC 0.5.0-rev4065
Language : Swedish
General
Complete name : Y:\Movies\Adventure\Gladiator (2000).mp4
Format : MPEG-4
Codec ID : isom
File size : 1.09 GiB
Duration : 2h 50mn
Overall bit rate : 909 Kbps
Movie name : Gladiator
Genre : Adventure
Description : Fans of Gladiator's original theatrical release will appreciate this extended version of the epic Ridley Scott film, packed with extra action footage and gripping dialogue. Featuring a strong supporting cast and an Oscar-winning performance from actor Rus
Recorded date : 2000
Encoded date : UTC 2010-05-21 07:34:40
Tagged date : UTC 2011-11-15 18:36:08
Cover : Yes / Yes
LongDescription : Fans of Gladiator's original theatrical release will appreciate this extended version of the epic Ridley Scott film, packed with extra action footage and gripping dialogue. Featuring a strong supporting cast and an Oscar-winning performance from actor Russell Crowe as the dauntless Roman general Maximus, this big-budget Best Picture winner became an instant classic -- and helped elevate its leading man to icon status.
Video
Format : AVC
Format settings, ReFrames : 16 frames
Codec ID : avc1
Duration : 2h 50mn
Bit rate : 702 Kbps
Maximum bit rate : 3 941 Kbps
Width : 716 pixels
Height : 368 pixels
Display aspect ratio : 2.35:1
Original display aspect ratio : 2.35:1
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.111
Stream size : 858 MiB (77%)
Writing library : x264 core 95 r1592 95aacc4
Encoding settings : cabac=1 / ref=16 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Tagged date : UTC 2010-05-21 07:36:24
Audio #1
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 2h 50mn
Bit rate : 92.3 Kbps
Maximum bit rate : 122 Kbps
Stream size : 113 MiB (10%)
Title : English
Language : English
Encoded date : UTC 2010-05-21 07:35:54
Tagged date : UTC 2010-09-21 08:19:10
Audio #2
Format : AAC
Format profile : HE-AAC / LC
Codec ID : 40
Duration : 2h 50mn
Bit rate : 60.9 Kbps
Maximum bit rate : 80.9 Kbps
Sampling rate : 48.0 KHz / 24.0 KHz
Stream size : 74.5 MiB (7%)
Title : English - Director's Commentary
Language : English
Encoded date : UTC 2010-05-21 07:36:03
Text #1
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Bit rate : 1 709 bps
Maximum bit rate : 4 240 Mbps
Stream size : 2.09 MiB (0%)
Language : English
Encoded date : UTC 2010-05-21 07:36:06
Text #2
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Language : English
Encoded date : UTC 2010-05-21 07:36:13
Text #3
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Bit rate : 1 748 bps
Stream size : 2.14 MiB (0%)
Language : French
Text #4
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Bit rate : 1 749 bps
Language : French
Encoded date : UTC 2010-05-21 07:36:17
Text #5
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Bit rate : 1 693 bps
Stream size : 2.07 MiB (0%)
Language : Spanish
Text #6
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Language : Spanish
Encoded date : UTC 2010-05-21 07:36:19
Text #7
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Bit rate : 2 451 bps
Maximum bit rate : 4 261 Mbps
Stream size : 2.99 MiB (0%)
Language : English
Text #8
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Language : English
Encoded date : UTC 2010-05-21 07:36:22
Text #9
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Bit rate : 30 bps
Maximum bit rate : 4 001 Mbps
Stream size : 37.2 KiB (0%)
Language : French
Text #10
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Bit rate : 30 bps
Language : French
Text #11
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Bit rate : 5 190 bps
Maximum bit rate : 4 267 Mbps
Stream size : 6.34 MiB (1%)
Language : English
Text #12
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Language : English
Encoded date : UTC 2010-05-21 07:36:23
Text #13
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Bit rate : 4 279 bps
Language : French
Text #14
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Language : French
Encoded date : UTC 2010-05-21 07:36:24
Text #15
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Bit rate : 4 464 bps
Stream size : 5.46 MiB (0%)
Language : Spanish
Text #16
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Language : Spanish
Text #17
Format : Timed Text
Codec ID : tx3g
Duration : 2h 43mn
Bit rate : 47 bps
Stream size : 56.6 KiB (0%)
Language : English
Menu #1
00:00:00.000 : Chapter 1
00:07:13.867 : Chapter 2
00:12:50.333 : Chapter 3
00:18:44.667 : Chapter 4
00:23:29.000 : Chapter 5
00:32:57.400 : Chapter 6
00:37:33.633 : Chapter 7
00:40:49.300 : Chapter 8
00:47:30.833 : Chapter 9
00:51:33.800 : Chapter 10
00:55:42.000 : Chapter 11
01:02:18.467 : Chapter 12
01:09:53.733 : Chapter 13
01:19:04.467 : Chapter 14
01:29:17.267 : Chapter 15
01:37:06.933 : Chapter 16
01:41:30.633 : Chapter 17
01:51:53.067 : Chapter 18
01:56:30.233 : Chapter 19
02:00:37.233 : Chapter 20
02:04:35.667 : Chapter 21
02:12:12.067 : Chapter 22
02:13:25.567 : Chapter 23
02:24:07.733 : Chapter 24
02:28:40.733 : Chapter 25
02:34:12.400 : Chapter 26
02:38:34.933 : Chapter 27
02:42:48.900 : Chapter 28
02:50:47.433 : Chapter 29
Menu #2
Codec ID : text
Duration : 2h 50mn
Encoded date : UTC 2010-05-22 07:39:02
Tagged date : UTC 2010-05-22 07:39:02
Bit rate mode : VBR
