dschwartzer
Jan 09, 2017Luminary
ReadyDR Not Working
I had ReadyDR working fine and now it has stopped again.
I have a RN526X as my main server and a RN314 as a backup server. Both are running OS 6.6.0.
The RN526X is in a downstairs office and the 314 is in an upstairs office and powers up in the evening to do a backup (using Rsync) of the 526X and for the ReadyDR jobs.
To create the ReadyDR jobs I did the Key exchange from the 526 and imported it to the 314. I created several shares on the 314 (i.e. PicturesDR) and set up a ReadyDR job from the (Local) Pictures share on the 526 to the (Remote) PicturesDR share on the 314. I have confirmed that the IP address for both servers is correct.
When I try to manually run the ReadyDR job, the 526 shows the job ran (although it is almost instantanious) but nothing appears in the DR share on the 314.
I have deleted all of the ReadyDR jobs and recreated them. I have deleted the key and did a new key exchange and checked all the settings but it still doesn't work.
I feel like I am forgetting something, especially since I had this working one before but I can't find what I am doing wrong.
I should also mention that the regular Rsync backp job is running correctly so I know the two units are talking to each other. I also am not getting any error messages.
The 526 ReadyDR jobs all have a green dot next to them and say Idle and the Last backup only changes when I try to so do a manual ReadyDR (Start) but nothng happens and the History is blank.
Any help would be appreciated.
regards,
David
ReadyNAS OS 6.6.1 is now available!
Did you follow the steps in the ReadyDR articles linked to by the ReadyNAS Backup FAQ?
- dschwartzerLuminaryIt appears the DR jobs that I ran manually did run and complete. I am going to see if the jobs run on their own as scheduled and will report back tomorrow.
- mdgm-ntgrNETGEAR Employee Retired
Did you follow the steps in the ReadyDR articles linked to by the ReadyNAS Backup FAQ?- dschwartzerLuminary
Dear mdgm:
Yes. Several times. I just reviewed them again and I believe I hve followed them as listed.
David
So do you still have this problem on 6.6.1?
