FreshIdentity
Mar 27, 2017Aspirant
ReadyNAS 102 – Blue light blinking, no boot
My ReadyNAS 102 has been working with an issue for a few years. I tried to connect recently and it wouldn't let me. I tried to reboot and it wouldn't so I pulled the power. Now it won't boot up (blue...
- Mar 27, 2017
Hello FreshIdentity,
Booting the NAS with no disks will really not boot up the NAS completely and will give you blinking power light. The OS/firmware, settings and data are stored to the disks.
Perhaps you want to check if RAIDar will detect your NAS with the disks in. By the way, when inserting the disks back to the NAS, please make sure you insert them back to their respective bays.
When RAIDar detects the NAS, it will show the current firmware, the current status and RAID level.
If the RAID level is XRAID (RAID1), try inserting just one disk to the NAS and see if it will boot up and let you access the files. If you get the same problem, try the other disk.
Welcome to the community!
JennC
Mar 27, 2017NETGEAR Employee Retired
jak0lantash
Mar 27, 2017Mentor
JennC wrote:If the RAID level is XRAID (RAID1), try inserting just one disk to the NAS and see if it will boot up and let you access the files. If you get the same problem, try the other disk.
I don't want to be annoying but this isn't a valid troubleshooting step. If the data volume is RAID0 or JBOD, you may damage it.
