FreshIdentity
Mar 27, 2017Aspirant
ReadyNAS 102 – Blue light blinking, no boot
My ReadyNAS 102 has been working with an issue for a few years. I tried to connect recently and it wouldn't let me. I tried to reboot and it wouldn't so I pulled the power. Now it won't boot up (blue...
- Mar 27, 2017
Hello FreshIdentity,
Booting the NAS with no disks will really not boot up the NAS completely and will give you blinking power light. The OS/firmware, settings and data are stored to the disks.
Perhaps you want to check if RAIDar will detect your NAS with the disks in. By the way, when inserting the disks back to the NAS, please make sure you insert them back to their respective bays.
When RAIDar detects the NAS, it will show the current firmware, the current status and RAID level.
If the RAID level is XRAID (RAID1), try inserting just one disk to the NAS and see if it will boot up and let you access the files. If you get the same problem, try the other disk.
Welcome to the community!
FreshIdentity
Apr 05, 2017Aspirant
Soooo. I got my new drive today and replaced it as instructed in bay 1. The other drive (Drive 2) then procedeed to sync with Drive 1 (I have a RAID1 setup) and when it finished I got an error saying the drive had synced but volume data was still degraded and now it's resyncing. Now I'm totally confused – have I replaced a drive unecessarily or are both drives bad (but what are the chances of that)?
coloatty
Apr 05, 2017Luminary
Patience. This is normal. First, the RAID volume is shaped. Then the data is synced to the RAID partitions on the drives. After the resync has happened and the volume switches from DEGRADED to REDUNDANT after the second run through, everything should appear normal.
