mesteele101
Oct 04, 2013Tutor
ReadyNAS 102 - Adding drive 2 & Plex / Torrent
I just ordered a RN10200 to move my Plex streaming from my windows box to a dedicated device. I want to eventually mirror two drives, but right now I only have a single 4TB drive to install into the R...
mesteele101
Oct 04, 2013Tutor
StephenB wrote: That works fine, though hopefully you are aware that the RN102 is not capable of transcoding.
mesteele101 wrote: I just ordered a RN10200 to move my Plex streaming from my windows box to a dedicated device.
I'm not really sure about transcoding. I'm using the Roku 3 on a wired gigabit / wireless N network. I just checked my Roku 3 and Transcoding was set to automatic. I guess I need to find/ask more questions about how to make Plex on the ReadyNAS 102 and the Roku 3 optimal? The video files I view are; .avi, .mp4, and .mkv
StephenB wrote: Yes. The default RAID setting of "xraid" will do exactly that. Just hot-insert the second drive and it should happen automatically.
mesteele101 wrote: Question 1) Will I be able to slide the 4TB drive 2 in at a later time and mirror (RAID-1) without loosing all the information on drive 1?
That makes it easy.
