TheBraf
Sep 19, 2017Guide
ReadyNAS 102- S.N. 3ERC4AE200216 - wrong dir/file management
Something happens when I add a folder called "J11-Roncadelle 17-09-2017" to the data previously stored on disk, using the web page provided by "readycloud.netgear.com". in details: I start from a r...
TheBraf
Sep 25, 2017Guide
Hi Marty,
attached the screenshot of what a I see from the PC
and the picture of what I see on the TV
TV-KO-2PC - OKTV-KO-1
I've performed further tests
1-
I noticed both ReadyDLNA and SMB services were enabled
I disabled the ReadyDLNA (SMB only) service and from VLC-Phone ONLY I see files on NAS in the correct way, BUT of course TV and STB does not support SMB
enabling ReadyDLNA only (no SMB) the wrong state comes again
2-
I removed, by means of web-page the forlder "2017" (parent of "J11-....")
from browser I see the right state, but on TV I still see the "J11-...." folder
3-
I deletd the VOLUME related to the disc
I re-installed the VOLUME related to pictures
I backupped from external USB3 disc the complete tree (with "2017" and "J11-...." folders)
all devices see the NAS files in the right way .....
..... but I do not think this is a solution
about your questions:
Have you tried creating a folder using simple name without using special character - and space?
>>> yes, I renamed the "J11-...." into "test", but I still see the "J11-...." folder
What firmware is the NAS running
>>> 6.8.0
the directory where the specific folder is created.
>>> as you can see fron the screeshot the complete path was
>>> \Foto-Filmati\2017\0-MTB\J11-Roncadelle 17-09-2017
>>> no "strange" char in my opinion
Many Thanks
Marty_M
Sep 25, 2017NETGEAR Employee Retired
Hello TheBraf,
Please check if Enhance macOS feature under SMB is enabled. If so please try to disable it and check if that will help. Firmware version 6.8.1 is now officially available you may want to upgrade the firmware and check if that will make any difference.
Marty_M
NETGEAR Community Team
- TheBrafSep 25, 2017Guide
"Please check if Enhance macOS feature under SMB is enabled. If so please try to disable it and check if that will help."
>>> in the past I completely disabled SMB service, keeping DLNA running only. nothing changed
" Firmware version 6.8.1 is now officially available you may want to upgrade the firmware and check if that will make any difference."
>>> it is now running 6.8.0. and trying to get update the system tell me there are no version (attached .... in italian)
Rgds
Stefano
- Marty_MSep 26, 2017NETGEAR Employee Retired
Hello TheBraf,
I believe the 6.8.1 firmware is not yet available on our server so automatic update will not work. For this concern you may need to manually upload the firmware to the NAS, please go to this link where you can download the firmware and where you can find the steps to manually upgrade the firmware.
Marty_M
NETGEAR Community Team- TheBrafSep 26, 2017Guide
Hi Marty,
I'll do, but looking at change-log it seems to me there are no fix in relation to DLNA
Stefano
- Marty_MSep 27, 2017NETGEAR Employee Retired
Hello TheBraf,
I understand that on the release notes there is no specific information about a fix but we still encourage to troubleshoot and work with the NAS running on the latest firmware. Have encountered the same problem on other folder or just this specific folder or just this name of folder?
Marty_M
NETGEAR Community Team- TheBrafSep 27, 2017Guide
Hi Marty,
ok, I'll update the FW.
I had the same issue in the past adding one single in a different directory.
I do not rememer the file name, but I'm sure it did not contain strange char, the folder too.
Rgds
Stefano
