YorkBoy
May 26, 2016Luminary
Readynas-102-not-backing-up-and-freezing......continued! #26140511
This thread was closed as having been solved but in fact so far only one of the three issues has been solved.
The issues were.
1) Slow backups taking 5 times as long under 6.4.0, now solv...
- Jun 29, 2016
I just thought that I would post and inform everyone that the problem has been solved satisfactorily and everything is working now, in fact better than it ever has been.
The problem with slow back ups both to USB drives and NAS to NAS has been a curse ever since my firmware was upgraded from 6.2.5 to 6.4.0 and beyond. Although about a month ago the USB backups were back to normal taking about 1.5 hours instead of the 5 hours under 6.4.0 the NAS to NAS backups were still taking a day. The front socket refuses to work at all failing completely for some unexplained reason.
Yet for the sake of repeating myself all used to work absolutely fine under 6.2.5.
By the way, during the course of digging out some paperwork I discovered the original advert for the 102. I says it's suitable for home and small business use so the comment on here from a Netgear 'expert' some months back that I shouldn't be using the 102 for my small business use was utter horlicks.
So how did I solve the issue you may be wondering?
I took advice and based on that after 8 months of pointless hassle, much of it here with seemingly little hope of ever resolving the issue, I rejected the 102 as being unfit for purpose, I had the unit returned for a full credit and am now running a Synology NAS.
So Netgear can stick their kit where the sun don't shine.
Have a nice day.
YorkBoy
May 31, 2016Luminary
Interesting thought.
Was wondering if I was to try to obtain a powered USB hub, plug this into the front socket, plug the Corsair into this and then run the backup routine?
When I tested the power consuption of the Corsair plugged directly into the 102 I was measuring around 110mA peak which as we know should be acceptable.
This doesn't explain the ghost share.
How can I get a screen shot jpg file to you to show this?
May 31, 2016Guru - Experienced User
You can post screen shots using the image icon in the forum toolbar.
The power spec for USB 2 is 500 ma, so of course the corsair was well below that. Can you measure power peaks, or just average?
- YorkBoyMay 31, 2016Luminary
Its a digital device that measures current and shows measurements at 1 sec intervals. So watching this while the backup took place I never saw a reading above 110mA.
Screenshot here.
Note identical sizes etc but different names. So two shares shown when the one external drive (generic) was installed.
