BilboD
Jun 24, 2016Aspirant
ReadyNAS 102 not being recognised by my LG TV after updating to 6.5.0 firmware
I have been succesfully streaming from my ReadyNAS 102 to my smart LG TV ever since I got it . Recently I added a TV series onto the HDD, but my smart TV did not find the folder. Now a week later m...
- Jun 30, 2016
Hi BilboD,
I apologize for the inconvenience this has caused you. Also big thanks for the very detailed info and troubleshooting you did on your own. Kindly check my suggestions below.
1. Disable ReadyDLNA completely under System->Settings->Services.
2. Re-enable it and rescan for local media files.
3. Once done, reconfigure the DLNA media settings of the share where the said media files are stored (tick the all checkbox).
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
BrianL2
Jun 30, 2016NETGEAR Employee Retired
Hi BilboD,
Hope this helps!
Kind regards,
BrianL
- BilboDJul 03, 2016Aspirant
Well, I haven'y checked through the TV yet, but I suspect your answer will have resolved the problem. On going through your steps I discovered that the DLNA option had already been deselected (possibly due to the firmware upgrade). I have enabled DLNA and rescanned so hopefully all is hunky dory. Thank you for the step through.
Bilbo
- BrianL2Jul 04, 2016NETGEAR Employee Retired
Hi BilboD,
It was nothing. Just let me know if this fixes your issue and don't hesitate to ask if you have other questions.
Kind regards,
BrianL
