tthumb's avatar
tthumb
ReadyNAS 102 Power Led 2 flashes pause repeat endlessly
I had a 2 TB disk. I am good with a single disk. I added a 5TB. It synced and was ready after a few hours. I pulled out the 2TB disk from the first bay. Confirmed I could access data and Admin UI. Mo...
  • StephenB's avatar
    Jun 23, 2021
    tthumb wrote:
    Bottom line: I want it to see and access the full 5TB.  What do I need to do?
    Start over.  The procedure you followed gave you a 2 TB RAID-1 volume (since RAID-1 is mirrored, the volume is the size of the smaller disk).  Then removing the 2 TB drive gave you a degraded RAID-1 volume.
    What you should have done is switched to flexraid, inserted the new disk, and created a new JBOD volume.  Then create new shares on the new disk, and copy the data over (backup jobs are convenient).  Finally, destroy the old volume, remove the old disk, and rename the new shares to match the original.
    Getting there from where you are is a bit tricky.  If you can connect the old disk to a PC, you might find it easier to simply copy off all the files from the NAS to the PC, and then do a factory default and set it up again.
ProSupport for Business
