rick1588
Feb 26, 2020Aspirant
ReadyNAS 102 replace disk now problems with second one
Replaced Disk 2 in my RAID Level 1 NAS102 system and almost immediately starting getting errors on Disk 1. Not sure if I should replace second disk at this point? After using the 2-drive NAS for ...
- Feb 26, 2020
rick1588 wrote:
Thanks for your quick reply. Is it normal that the status would show different in RAIDar vs. the admin page?
Not Redundant and Degraded are two different ways of giving exactly the same status.
Disk 1 has failed and is no longer part of the array, and it needs to be replaced. It would be wise to back up your data before replacing the disk.
rick1588 wrote:
but is there any concern that it will not be able to properly sync due to the "Not Redundant" or "Degraded" status?
To be clear, the resync is needed to recover from the degraded status. However, there is risk - if disk 2 fails during the resync, then your data would be lost.
Sandshark
Feb 26, 2020Sensei
Yes, it appears you need to replace drive 1 and you are very lucky the re-sync completed before that drive went offline.
rick1588
Thanks for your quick reply. Is it normal that the status would show different in RAIDar vs. the admin page? I don't mind replacing another disk but is there any concern that it will not be able to properly sync due to the "Not Redundant" or "Degraded" status?
- StephenBFeb 26, 2020Guru - Experienced User
- rick1588Feb 27, 2020Aspirant
I understand and have ordered the replacement disk. Thanks for explaining.
