EFrankWade
Feb 29, 2016Aspirant
ReadyNAS 102 Source will not MOUNT
Win 7 PC - Norton Internet is off. The source director can be accessed from two (2) other PC. One Windows Home Server and another Win 7. Alll on same 1 GB network (WadeGroup) I have spent...
- Mar 03, 2016
Stephen,
Thank you for your suggestions on my issue. I was able with your help, and a little luck, to get the ReadyNAS to WORK. The final solution was to use the source IP in the Host field instead of the computer name. Another interesting item is that the windows DNC back slash "\" is automaticly changed to Unix foward slash "/" when I selected the start button. Keep up the good work.
Frank
EFrankWade
Stephen,
Thanks for the input. Everything looks good on the ReadyNAS side. I am not able to use the "Browse" feature on the source setup side tro find the files to backup.. Could this be my issue? Frank
Feb 29, 2016Guru - Experienced User
EFrankWade wrote:
Stephen,
The browse control is local (for the NAS). I'd assumed the source was the remote PC???
- EFrankWadeFeb 29, 2016Aspirant
tephen,
You are correct.. . . However I can see the files I want to backup from the CMD line on two other computers. the IP "Pings" Also, when i "Test the Connection" on the source setup I get the sucess conformation message.
The folllwing log comment is generated.
Backup Job Name: Frank BU
Backup Job Type: Incremental
Protocol: cifs
Backup Source: [remote:cifs]///Insprion/C:/Users/E. Frank/My Documents
Backup Destination: [Documents]/FrankBU
Backup Start Time: Mon Feb 29 2016 19:01:12
Backup Finish Time: Mon Feb 29 2016 19:01:33
Backup Status: Fail: source cannot be mounted on the system.Failed to mount remote path //Insprion/C:/Users/E. Frank/My Documents!
There are no system error codes to reseaech. Any other suggestion I can try?
Frank
- mdgm-ntgrFeb 29, 2016NETGEAR Employee Retired
That Remote path does not look correct. C:\Users\E. Frank\My Documents would be the local path to the directory on the PC, not a network path.
The path needed may be //Insprion/c$/Users/E. Frank/My Documents or something like that
Note that for UNC paths on Linux machines (e.g. the NAS) slashes go the opposite way to on a PC.
Do you have another PC on your network?
If so, can you check if you can access the Backup source path using that? Using another PC you should be able to find the correct path.- EFrankWadeMar 01, 2016Aspirant
Stephen,
Sorry for the delayed response. I did a recheck and I can see the files I want to backup from two other PC's on my network. I tried the UNC both ways and still the source will not mount. I am in the process doing a hard reboot and reformating . Well keep you posted. . . Frank
