williamyzfr1
Jan 19, 2014Guide
ReadyNAS 102 USB Drive
Hello, I am new to all this and I have searched in vain for an answer. I am running the latest firmware (6.1.5) and connected a USB disk to a rear USB port. I can see and browse the disk using the ...
vandermerwe
Jan 19, 2014Master
First upgrade to the newest beta firmware, there are some usb device fixes on it although I don't think this is your issue:
viewtopic.php?f=154&t=72282
Is the usb device setup as a share - you'd need to set permissions on the readynas then to allow your windows user to access the disk.
Setup a user on the readynas that is identical to the windows user then give access to the usb share using the GUI. Also, after you have done this, you may need to use the "Reset permissions" tickbox which is in the share properties
