dwitkin
Aug 29, 2015Aspirant
ReadyNAS 102 With X-RAID Not Expanding Storage, Device Becomes Unreachable
Hi. I've been using a ReadyNAS 102 for about 9 months now. I had a 1.5TB WD hard disk in bay 1 and a 1.0TB WD disk in bay 2. Everything was working great.
I decided I would upgrade both disks to 3TB Western Digital HD-W30EFRX. Before purchaing them, I looked the drives up and they were on the ReadyNAS compatibility list.
I'm using X-RAID (/RAID 1, I believe - redundant disks only). Here's a quote from the software user guide on adding disks:
X-RAID accommodates the new disks automatically. You can replace
existing disks with larger-capacity disks and X-RAID automatically accommodates the new disks.
Based on the quote and reading a few related posts, I thought I could just: (a) remove either of the two existing disks; (b) add one new disk; (c) let the new disk sync the data; (d) remove the remaining 'old disk'; (e) replace it with the remaining new, 3TB disk, and then (f) let the new disk synce the data.
Unfortunately, I've tried this with two different new hard drives on the compatibility list and it isn't working for me. Neither of the new hard drives is formatted. I remove one of the old disks, insert one of the new 3TB disks, and at that point the ReadyNAS becomes unreachable via its web admin page, RAIDar, or through the Windows network. I've waited several hours, and even after that much time the device does not become reachable. The ReadyNAS also is unable to gracefully shutdown using the power button. In short, the hardware appears to be frozen.
I also tried the same process but started with a powered down state, and that didn't work either -- the power button just went into slow blink mode and the ReadyNAS was not reachable as above.
When I remove all the old disks and put one of the new, unformatted 3TB disks in the drive and power-up, the new drive is recognized fine and the ReadyNAS is reachable. So, I know I can now backup all my data from the old disks to my computer, remove the old disks from the ReadyNAS and insert the new disks, and then restore the backup to the new disks. But I thought one of the key advantages of using X-RAID is you shouldn't have to do that.
Before I go through the full backup / swap / restore process mentioned above, are there other solutions I should try to resolve the issue?
Thanks for your help!
Dave
The process you outline (hot-swap one drive at a time) is the right one. I'm don't know why it isn't working for you. It will take several hours to resync, though normally the UI would be available for most of that time (just slow).
Do you have other apps running (antivirus, etc) that could be adding to the CPU load?
- dwitkinAspirant
Hi Stephen. Thanks for the response.
No, I don't have anti-virus running, but I do run a Plex server and the Logitch Media Server on the ReadyNAS. Nothing is / was streaming, though.
- mdgm-ntgrNETGEAR Employee Retired
Well you could still try turning off the apps and seeing if that helps.
Which firmware are you running?
