BlueJem
Mar 07, 2017Follower
ReadyNAS 10200 won't turn on after moving it...
Hi, Bought this unit just over 2 years ago and inserted 2 western digital drives and set them up to mirror each other. All has been fine. It's being used to back up photos, music files and work docum...
Mar 07, 2017Guru - Experienced User
The symptoms sound like either a broken power connection or a power brick failure.
The warranty is three years, so you should contact Netgear support on this (my.netgear.com).
