BlueJem
Mar 07, 2017Follower
ReadyNAS 10200 won't turn on after moving it...
Hi, Bought this unit just over 2 years ago and inserted 2 western digital drives and set them up to mirror each other. All has been fine. It's being used to back up photos, music files and work docum...
Sandshark
Mar 08, 2017Sensei
If the LAN activity LED lights up when the unit is connected to an active ethernet cable even when powered off, then it's probably not the supply. The ethernet and power-on circuit both run on standby power so you can turn it on with the button or WOL.
