JRB578
Apr 12, 2016Follower
ReadyNAS 104 - could not access after bonding network adapters
Hello, I re-configured my ReadyNAS 104 (4x4TB drives). I set its network adapters to bond (adaptive load balancing). After rebooting the NAS, I can no longer access it. The display on the NAS sho...
mdgm-ntgr
Apr 12, 2016NETGEAR Employee Retired
You could do an OS Re-install which would reset the network settings for your NICs and the admin password. See How do I access the boot menu on my ReadyNAS 104, 204, 214, or 314?
Why did you decide to use NIC Bonding?
Apr 13, 2016Guru - Experienced User
The first thing to try is to remove one of the ethernet cables and reboot.
