voidness
Dec 28, 2015Guide
ReadyNAS 104 - Slowness with Firmware 6.4.1
I just want to report that the latest firmware 6.4.1 is extremely slow, SMB is pretty much unusable (takes 5 mins to load the list of files on big directories) NFS is at best 5M/s and subjected to ra...
mdgm-ntgr
Dec 28, 2015NETGEAR Employee Retired
We have 6.4.2 Beta firmware now available: https://community.netgear.com/t5/ReadyNAS-Beta-Release/ReadyNASOS-6-4-2-T59-Beta-1/td-p/999457/jump-to/first-unread-message
Some users reported that on 6.4.1 after disabling AV performance returned to normal.
- fxmailDec 29, 2015Guide
I have the same issue. and disabling anti virus is a work around but why wont the engineers test their firmware before they release it. I have a case open and the tech I am dealing with Abigail Anduyan doesnt care. they want me to replace the hardware for a slowness problem and I want them to find out if they replace under warranty a new unit or a refurnbished one. Thaty is all I am asking and Abigail Anduyan does not want to help me. I want to know because I am not sure this will fix my issue after I spend money shipping for a replacement that is all beat up.
I have had nothing but problems since upgrading to 6.4.0. If your on 6.2.5 do yourself a favor and stay at that level. DO NOT UPGRADE.- mdgm-ntgrDec 29, 2015NETGEAR Employee Retired
fxmail, we do test firmware before we release it and we are working on the anti-virus issue.
Our warranty permits us to replace hardware that fails with refurbished units. If you are not satisfied with the condition a replacement unit comes in you can send us hi-res photos of the problem for us to review.
I understand in your case #25993341 that Out of Memory errors are still occurring despite various setting changes having been made. This has led to support to suspect hardware failure.
The Out of Memory problem I can see in the logs from December 15th relates to high memory usage from the anti-virus service.
