mickle026
Oct 19, 2015Aspirant
ReadyNAS 104 Convert X-Raid to Flex Raid - will it expand space for data?
Hi, Before I start, my NAS is a media server and im not really bothered about backup and data recovery on it as nothing on it is crutial that it is kept. Having said that I have a lot of data...
mickle026
Oct 21, 2015Aspirant
Thank you so much.
I have been networked since bnc and terminators, but I have to say although I knew of raid, I have never used it or had the need so never did any exploration of it.
I have always used network attached storage as mounted drives and used a custom data copy script as a backup.
I originally had no intentions of keeping backups of this data because it's not that important to keep, however now I'm pondering it. I never had more than 4 machines in my network, but now I have 9 it's starting to look like I might need raid one day.
Thank you so much for the information, I obviously have more reading to do on the subject.
- itsjasperOct 21, 2015Luminary
This is a good primer on RAID: http://www.thegeekstuff.com/2010/08/raid-levels-tutorial/
It doesn't cover RAID6 in the article, but just imagine RAID5 with an extra disk with another parity block stripe. There's a link to an additional article explaining RAID6 as well.
On a 4-bay NAS such as the 104, it probably makes more sense to have a 5th hard disk as a spare, sitting on the shelf as insurance, rather than run RAID-6. Set up email alerting and get timely notifications on drive failures. There is also a greater write penalty on RAID6 compared to RAID5, as there is the extra parity block write.
- StephenBOct 21, 2015Guru - Experienced User
Yes. I wouldn't recommend RAID-6 on the RN104. The Q parity blocks are harder to compute than the simple XOR used for P, and there is a big performance hit.
Keeping a spare drive handy is a good strategy, as it can take a few days for a replacement to arrive.
And of course, backups...
