pappylapoo
Apr 12, 2018Follower
ReadyNas 104 stuck booting
Hi All, My readynas 104 is stuck booting at about 60% "Systemd-Update-U" on the LCD display. I have tried the following: 1. OS-Reinstall 2. Factory Reset 3. USB recovery 4. Changed disks ...
- Apr 12, 2018
This should be fixed now (Successfully completed USB Boot Recovery should have also been able to resolve this).
Also the system time of your system had been set back to 1925 for some reason. That should be fixed as well.
mdgm-ntgr
Apr 12, 2018NETGEAR Employee Retired
Sounds like you could have had a partially completed update, perhaps with a different firmware loaded onto the disks than the firmware used by the early boot process and the kernel.
