sokol_44
Feb 18, 2017Aspirant
ReadyNas 104, stuck in booting... after upgrade to 6.6 from 6.4.2
Automatic update from 6.4.2 to 6.6 ( i think 6.6.0) Stuck at "booting 99%", SSH and SMB works. Logged and service readynas wont start: # systemctl status readynasd
● readynasd.service - ReadyN...
- Feb 26, 2017
A factory reset was a rather drastic step to take. I have sent you a PM.
mdgm-ntgr
Feb 19, 2017NETGEAR Employee Retired
How full is the root volume?
# df -h # df -i
You can confirm the firmware version:
# cat /etc/os_version
Do you have any apps installed? If so, which ones?
sokol_44
Feb 20, 2017Aspirant
Additional mount is for backup where i try to move everything in case i need hard reset.
# df -h Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 4.0G 906M 2.9G 24% / tmpfs 249M 0 249M 0% /dev/shm tmpfs 249M 452K 248M 1% /run tmpfs 125M 732K 124M 1% /run/lock tmpfs 249M 0 249M 0% /sys/fs/cgroup /dev/md127 5.5T 3.2T 2.4T 58% /data /dev/md127 5.5T 3.2T 2.4T 58% /home /dev/md127 5.5T 3.2T 2.4T 58% /apps 192.168.1.17:/mnt/hbz1/all 2.6T 732G 1.9T 28% /mnt/freenas
~# df -i Filesystem Inodes IUsed IFree IUse% Mounted on udev 63154 440 62714 1% /dev /dev/md0 65536 18474 47062 29% / tmpfs 63590 1 63589 1% /dev/shm tmpfs 63590 580 63010 1% /run tmpfs 63590 24 63566 1% /run/lock tmpfs 63590 9 63581 1% /sys/fs/cgroup /dev/md127 0 0 0 - /data /dev/md127 0 0 0 - /home /dev/md127 0 0 0 - /apps 192.168.1.17:/mnt/hbz1/all 3978873730 25656 3978848074 1% /mnt/freenas
# cat /etc/os_version ReadyNASOS!!version=6.6.1,time=1482880160,arch=arm,descr=ReadyNASOS
# ls -l /data/.apps total 0 drwxr-xr-x 1 root root 52 Jun 26 2014 APPGENIE dr-xr-xr-x 1 root root 0 Jun 18 2014 DO_NOT_DELETE drwxr-xr-x 1 admin admin 124 Aug 28 2014 phpsysinfo drwxr-xr-x 1 root root 92 Nov 10 2014 rsyslog-app drwxr-xr-x 1 root root 132 Apr 16 2015 smbplus drwxr-xr-x 1 admin admin 128 Jul 12 2015 tftpr6
Also i had instalet "btsync" & "transmission", and i instaled from command line "mc", "screen" and for some timre "tor".
- sokol_44Feb 26, 2017Aspirant
So....
After a week without answer i decided to try factory reset.
Now i have box stuck at 99% Booting without SSH access :(
Lucky i have coppied `core-readynasd` if somebody wants to help me with that problem :/
Help......
