Agent4000
Jan 12, 2025Aspirant
ReadyNas 104 tries to boot to USB and fails.
I have a Read NAS RN104 and it doesn't when it powers on it tries to boot to USB and fails. I went through the USB recovery and it boots into the USB and says "DEBUG: telnet" Then an IP address. ...
Jan 12, 2025Guru - Experienced User
Agent4000 wrote:
RAIDar can find the NAS when it has booted from the USB, but it says that the model is "None", serial is "N0NE000~", Status in "Tech Support Mode", and debud code is "TELNET Mode". When it hasn't booted to the USB RAIDar can't find it.
Try accessing the NAS using Telnet. If you are using a windows PC, I suggest you use the Putty client for that.
https://www.chiark.greenend.org.uk/~sgtatham/putty/
Make sure you select "telnet" as the protocol.
When you connect to the NAS, log in as root. The password is infr8ntdebug.
Once logged in, enter these commands.
rnutil chroot
lsblk
If lsblk works, then post the output here, and we can proceed with attempting to manually mount your data volume.
Agent4000
Also, The firmware I have on the USB is OS-6.10.10 but radar reports 6.2.4
- StephenBJan 12, 2025Guru - Experienced User
What firmware was the NAS running before the failure?
Did you notice the update instructions here:
ReadyNAS 102, 104, and 2120 systems must not be updated directly to 6.10.x from 6.3.x or older firmware. They must first be updated to either 6.2.5 or 6.3.5, then to 6.5.2, and then to 6.10.x.
- Agent4000Jan 12, 2025Aspirant
I don't remember, I think 6.4
It has been a long time since I have been in the admin page in a long time- StephenBJan 12, 2025Guru - Experienced User
Maybe actually 6.2.4?
You could try a USB recovery using 6.2.4 firmware - that might work.
If you have a linux system (or can boot up a PC using a USB linux "live boot"), then it is possible to connect the disks to the linux system, and mount the data volume manually.
RAID recovery software that supports BTRFS would also work (for instance ReclaiMe) - that would require connecting the disks to a Windows PC.
You can migrate the disks to any OS-6 ReadyNAS with enough bays. Some older 4.2.x ReadyNAS can also be converted to OS-6, and you can migrate to those also.
