rivit
Oct 11, 2015Tutor
ReadyNAS 104 upgraded to OS 6.4.0 shutdown hang
Following upgrade to this release I am unable to shutdown. System hangs with "Shutting dow. Goodbye." - I left it in this state overnight. Power must be removed to complete shutdown.
- Nov 15, 2015
Can confirm beta 3 fixes the no shoutown with custom MTU issue.
Jophus
Nov 16, 2015Luminary
Thanks. No, I had the same problem upgrading 6.2.5 to 6.4.0 where it would not upgrade until I hard factory reset the box using a paperclip.
I will try a hard reset and see if that works. I had no problem upgrading 6.1.9 to 6.2.4 and then 6.2.5... But 6.4.0 has presented problems.
