rivit
Oct 11, 2015Tutor
ReadyNAS 104 upgraded to OS 6.4.0 shutdown hang
Following upgrade to this release I am unable to shutdown. System hangs with "Shutting dow. Goodbye." - I left it in this state overnight. Power must be removed to complete shutdown.
- Nov 15, 2015
Can confirm beta 3 fixes the no shoutown with custom MTU issue.
BrianL2
Dec 01, 2015NETGEAR Employee Retired
Hi BJB & Jophus,
The Official 6.4.1 Firmware is now available. Give us your thoughts and feedback.
Kind regards,
BrianL
NETGEAR Community Team
Retired_Member
Dec 09, 2015Hi BrianL,
since I updated to 6.4.1 everything runs as it should.
Before the situation got worse:
At first shutdown via ssh login worked sometimes and shutdown vie power button always worked.
At the end every method resulted in a blinking power button and an absolutely non responding ReadyNAS 104 where only pulling the plug could helped.
Now everythiong is fine sheduled shutdown works with and without activated spindown of disks. I never changed the MTU.
Thanks for the help
- gw_rocksDec 09, 2015Tutor
Hi.
6.4.1 seems to be ok for me as well. I turned on NAS manually during the day and it successfully shutdown at 11pm with my scheduled shutdown time. Before that it hung shutting down. So far so good.......
Grant.
- BrianL2Dec 09, 2015NETGEAR Employee Retired
Hi werwolf & gw_rocks,
It appears that the new Firmware resolved most of the issues experienced in 6.4.0. Also a big thanks for the positive feedback :)
Kind regards,
BrianL
