rivit
Oct 11, 2015Tutor
ReadyNAS 104 upgraded to OS 6.4.0 shutdown hang
Following upgrade to this release I am unable to shutdown. System hangs with "Shutting dow. Goodbye." - I left it in this state overnight. Power must be removed to complete shutdown.
- Nov 15, 2015
Can confirm beta 3 fixes the no shoutown with custom MTU issue.
rivit
Oct 14, 2015Tutor
The scheduled shutdown and hanging shutdown should be treated as two seperate issues until a link is proven. The scheduled shutdown seems to be problem with triggering the process. The 'hanging' shutdown is a problem completing the task/firmware receiving message for power off.
gw_rocks apprently is isn't possible to downgrade (well at least there isn't a supported method). I would leave it powered on until you hear otherwise :-)
BrianL2
Oct 14, 2015NETGEAR Employee Retired
Hi werwolf, gw_rocks, MartynHeat1 & rivit,
I've sent you guys all a PM. Please check your inbox.
Kind regards,
BrianL
NETGEAR Community Team
- DeisterbikerOct 15, 2015Aspirant
My ReadyNAS 102 hangs too after upgraded to 6.4
Best regards
Ralf
- grahamu59Oct 15, 2015Tutor
Looks like the same issue I am having in this thread...
Would this PM apply to me also?
