rivit
Oct 11, 2015Tutor
ReadyNAS 104 upgraded to OS 6.4.0 shutdown hang
Following upgrade to this release I am unable to shutdown. System hangs with "Shutting dow. Goodbye." - I left it in this state overnight. Power must be removed to complete shutdown.
- Nov 15, 2015
Can confirm beta 3 fixes the no shoutown with custom MTU issue.
Jophus
Oct 30, 2015Luminary
Notes from Netgear level 3 support below... I asked that spun down disks also be tested to see if they cause an issue, which they confirmed will be tested next week.........
Notes added by 34004
Hello, Sir
This is QingHong from Netgear level 3 engineer, this case was assigned to me.
According to my Experience, and I checked NAS logs, there are some kernel error, so I guess this issue was caused by MTU 9000.
I have reproduce this issue in my lab.
I will escalate this issue to R&D engineer, this need a bit long time to fix this issue, so please disable this function, and I will give you update when I received any feedback, thanks.
QH
[T060]
