rivit
Oct 11, 2015Tutor
ReadyNAS 104 upgraded to OS 6.4.0 shutdown hang
Following upgrade to this release I am unable to shutdown. System hangs with "Shutting dow. Goodbye." - I left it in this state overnight. Power must be removed to complete shutdown.
- Nov 15, 2015
Can confirm beta 3 fixes the no shoutown with custom MTU issue.
Jophus
Oct 30, 2015Luminary
Notes from Netgear level 3 support below... I asked that spun down disks also be tested to see if they cause an issue, which they confirmed will be tested next week.........
Notes added by 34004
Hello, Sir
This is QingHong from Netgear level 3 engineer, this case was assigned to me.
According to my Experience, and I checked NAS logs, there are some kernel error, so I guess this issue was caused by MTU 9000.
I have reproduce this issue in my lab.
I will escalate this issue to R&D engineer, this need a bit long time to fix this issue, so please disable this function, and I will give you update when I received any feedback, thanks.
QH
[T060]
grahamu59
Oct 31, 2015Tutor
MTU was the solution for me. Changed it to default & shutdown correctly last night. No other changes required.
- JennCOct 31, 2015NETGEAR Employee Retired
Hello all,
You guys might want to try the BETA FW 6.4.1-T21.
- BJBOct 31, 2015Aspirant
I have an RN104 and am running firmware 6.1.9 (I know, it is old but it works solidly).
Anyway, was going to upgrade and noticed this shutdown hang thread on the most recent firmware. I run the basic GUI front end, no command line settings.
Is there any setting on the regular Readynas browser GUI I should check to regarding MTU or anything like that before I upgrade my firmware? Has it been confirmed that is what causes this issue?
I know various firmware upgrades can cause issues but this is rather major as I don't keep my NAS up 24/7.I guess further (and perhaps this should be a new post), since I am jumping so many firmware versions is that an issue?
The thought of OS re-installs, etc. don't thrill me. I'll take risks with my phone or beta PC software but not my backup NAS. Do the veteran upgraders here suggest I wait a while for a new 6.4.X version?
Thanks for any suggestions,
BJB- BrianL2Nov 01, 2015NETGEAR Employee Retired
Hi BJB,
You can check the MTU settings of your ReadyNAS NIC under the Network tab. With regard to the issues that were reported in the community, most of them are different and they are being addressed now (with the release of the Beta Firmware). I recommend that you give it a try in updating the Firmware of your ReadyNAS and ensure that the unit is running either 6.2.4 or 6.2.5 versions.
Let me know if you have further questions.
Kind regards,
BrianL
NETGEAR Community Team
