rivit
Oct 11, 2015Tutor
ReadyNAS 104 upgraded to OS 6.4.0 shutdown hang
Following upgrade to this release I am unable to shutdown. System hangs with "Shutting dow. Goodbye." - I left it in this state overnight. Power must be removed to complete shutdown.
- Nov 15, 2015
Can confirm beta 3 fixes the no shoutown with custom MTU issue.
grahamu59
Oct 31, 2015Tutor
MTU was the solution for me. Changed it to default & shutdown correctly last night. No other changes required.
JennC
Oct 31, 2015NETGEAR Employee Retired
Hello all,
You guys might want to try the BETA FW 6.4.1-T21.
- BJBOct 31, 2015Aspirant
I have an RN104 and am running firmware 6.1.9 (I know, it is old but it works solidly).
Anyway, was going to upgrade and noticed this shutdown hang thread on the most recent firmware. I run the basic GUI front end, no command line settings.
Is there any setting on the regular Readynas browser GUI I should check to regarding MTU or anything like that before I upgrade my firmware? Has it been confirmed that is what causes this issue?
I know various firmware upgrades can cause issues but this is rather major as I don't keep my NAS up 24/7.I guess further (and perhaps this should be a new post), since I am jumping so many firmware versions is that an issue?
The thought of OS re-installs, etc. don't thrill me. I'll take risks with my phone or beta PC software but not my backup NAS. Do the veteran upgraders here suggest I wait a while for a new 6.4.X version?
Thanks for any suggestions,
BJB- BrianL2Nov 01, 2015NETGEAR Employee Retired
Hi BJB,
You can check the MTU settings of your ReadyNAS NIC under the Network tab. With regard to the issues that were reported in the community, most of them are different and they are being addressed now (with the release of the Beta Firmware). I recommend that you give it a try in updating the Firmware of your ReadyNAS and ensure that the unit is running either 6.2.4 or 6.2.5 versions.
Let me know if you have further questions.
Kind regards,
BrianL
NETGEAR Community Team- BJBNov 01, 2015Aspirant
Brian L,
Thanks, but I am a little confused. I have no problem checking the network settings. Got that.
But then you say to make sure that I am running firmware 6.2.4 or 6.2.5? Do you mean before I update to 6.4.x? I stated in my post that I am running 6.1.9. So,,,,,,,are you saying I need to do an interim update before I update to a 6.4. version? If so, where do I go to download an interim version like that and what are the install instructions? Of course when I logon to the drive, all that is offered is the most recent firmware.
Also, you say that the beta softare fixes some of the reported issues but yet you still say I should try to upgrade. If I want to be safe, would it not be better to wait until the beta software goes into release?
Thanks,
BJB
