stuart_2k
Nov 05, 2017Aspirant
ReadyNAS 104 X-Raid Not Expanding
Bought the 104 2 years ago with a 4TB hdd with the intention of adding new disks soon after. Fast forward 2 years and I finally got around to putting 3 more 4TB drives in. I assumed that hot inse...
- Nov 20, 2017
So, I ended up backing everything up again just to be sure, factory resetting and then it picked up all the disks and then copied it all back.
Took a long time, but it's back working again now!
Thanks for your help!
Sandshark
Nov 05, 2017Sensei
Do you have SSH access enabled, and can you post the results of an lsblk command? It sounds like it my have sync'ed your OS and swap volumes, but not the data one. You can wait, but I doubt anything will happen.
The only reason your one drive arrar wasn't "degraded" is because a single-drive volume never has any redundancy to degrade. I don't think your data is any more susceptible to loss now than it was with just one drive.
stuart_2k
Output of the command: lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 3.7T 0 disk
├─sda1 8:1 0 4G 0 part
│ └─md0 9:0 0 4G 0 raid1 /
├─sda2 8:2 0 512M 0 part
│ └─md1 9:1 0 1022M 0 raid10 [SWAP]
└─sda3 8:3 0 3.6T 0 part
└─md127 9:127 0 3.6T 0 raid1 /data
sdb 8:16 0 3.7T 0 disk
├─sdb1 8:17 0 4G 0 part
├─sdb2 8:18 0 512M 0 part
└─sdb3 8:19 0 3.6T 0 part
sdc 8:32 0 3.7T 0 disk
├─sdc1 8:33 0 4G 0 part
├─sdc2 8:34 0 512M 0 part
└─sdc3 8:35 0 3.6T 0 part
sdd 8:48 0 3.7T 0 disk
├─sdd1 8:49 0 4G 0 part
├─sdd2 8:50 0 512M 0 part
└─sdd3 8:51 0 3.6T 0 part
mtdblock0 31:0 0 1.5M 1 disk
mtdblock1 31:1 0 512K 1 disk
mtdblock2 31:2 0 6M 1 disk
mtdblock3 31:3 0 4M 1 disk
mtdblock4 31:4 0 116M 1 disk
- stuart_2kNov 06, 2017Aspirant
Did a bit more digging and it looks like the 3 new drives are set as warm spares. It might have synced the partition layout explaining how it was so fast.
mdadm --detail /dev/md127
/dev/md127:
Version : 1.2
Creation Time : Fri Sep 4 15:22:06 2015
Raid Level : raid1
Array Size : 3902166784 (3721.40 GiB 3995.82 GB)
Used Dev Size : 3902166784 (3721.40 GiB 3995.82 GB)
Raid Devices : 2
Total Devices : 4
Persistence : Superblock is persistent
Update Time : Mon Nov 6 09:13:05 2017
State : clean, degraded
Active Devices : 1
Working Devices : 4
Failed Devices : 0
Spare Devices : 3
Name : 43020200:data-0 (local to host 43020200)
UUID : b6e671e5:ce113ecb:42d212e3:d636db0b
Events : 645
Number Major Minor RaidDevice State
0 8 51 0 active sync /dev/sdd3
- 0 0 1 removed
1 8 35 - spare /dev/sdc3
2 8 19 - spare /dev/sdb3
3 8 3 - spare /dev/sda3- SandsharkNov 06, 2017Sensei
Somehow, it thinks you have a removed drive and it is holding the others in reserve to expand once that drive is replaced. One thing to do right away is make sure your backup is up to date in case this gets messy and you lose the volume completely.
Some things to try:
- Reboot
- Disable and re-enable XRAID
- With XRAID disabled select a drive and "add redundancy" from the drive options for one of them.
If those don't work, perhaps remove the "spare" drives and remove the partitions, then reboot and try all over.
