Phil_C
Feb 11, 2016Aspirant
ReadyNAS 1100 installation problem
Hello All I have just put four Seagate ST2000DM001 2tb drives in my ReadyNAS 1100 (Previously it had a single 1tb drive) The 1100 is past the first three steps and according to the manual the drives...
- Feb 12, 2016
Not all disks on the compatibility list are equal. And the 1100 was superceded back in 2009, so we haven't tested disks in this system in quite some time.
If a factory default (wipes all data, settings, everything) does not resolve the problem, please hook the disks up to your PC and delete the partitions off the disks.
mdgm-ntgr
Feb 12, 2016NETGEAR Employee Retired
This isn't normal.
Which firmware are you running?
Were these disks previously used in another system?
Also, not all disks are equal. I wouldn't recommend this particular disk model. SeaGate NAS 2TB or WD RED 2TB would have been preferable.
Phil_C
Feb 12, 2016Aspirant
The firmware is RAIDiator 4.1.14 [1.00a147]. As far as I could find this is the latest firmware for this device.
The disks were used on an adaptec 31205 raid adapter and were set to a striped mirrored array. Do you think I should connect them to a pc and format them? I thought the NAS would format the drives on installation.
I don't have any other disks to use in this system at this stage and the hardware compatibility list for the 1100 lists the ST2000DM001 so it should work. I could not find any mention of the NAS series drives in the HCL.
Regards
Phil
- mdgm-ntgrFeb 12, 2016NETGEAR Employee Retired
If a factory default (wipes all data, settings, everything) does not resolve the problem, please hook the disks up to your PC and delete the partitions off the disks.- Phil_CFeb 12, 2016Aspirant
The factory default reset did the trick. All disks are now showing up as an x-raid configuration and the syncronisation has partially completed (5 hours till completion).
Thanks again
Phil
