davidk1952
Mar 20, 2016Luminary
ReadyNas 200-4 RN 204 USB 3 transfer speed
I just purchased a ReadyNas RN204, 4 drive NAS I've been reading sas much as I can as quickly as I can and already, I have a couple of questions. 1. I have not been able to find a true transfer ...
- Mar 22, 2016
Thanks MDGM, that explains it and Yes, I plan to use the Netgear web interface for the direct copy. as I said, once I get my first transfer of all the current files I want to load up on it I will be fine, after that it will only be a few files at a time. I will use the USB 3.0 and the interface to do the transfer and go from there.
davidk1952
So, am I reading this correctly.. If I plug my External USB 3.0 HDD directly in to the NAS 3.0 port then use the Drag and Drop feature of he web based software that it actually does not do a direct transfer? That seems weird and unefficient for sure.
Sorry about my comment about bandwidth, but I was looking at using the Ethernet connection just as another step. I am thiking of my initial loading of my files to the NAS drives, after that the backups and subsequent loading of additional files will be not as large of a job.
Also, thanks for the answer regarding using an external HDD to back up the system..I"ll look at that as well...
I know this is another question but since I am here as as yet hooked up the drives in the unit my initial thought was to justs use the Netgear X format/raid from what I read I have 4 4TB drives and with the x format I'll have a total of 12 TB drives which should be more than enough for now.
Thanks again for the reply..
Mar 21, 2016Guru - Experienced User
The admin web is direct. Windows file explorer and OSX finder are not.
For bulk transfer I'd suggest a backup job instead - it is easy to set up.
XRAID is the best mode for most users. It will create a standard RAID-5 volume with this disk configuration, and you will have a 12 TB volume.
- davidk1952Mar 21, 2016Luminary
Thank you StephenB for the reply, I guess I'm just not use to the terms yet... just so I understand, A bulk transfer would be hooking up my external drive to the back of the NETGEAR NAS USB 3.0 and use the web based control panel to do a drag and drop? Other than using the Ethernet to control the transfer the files move directly?
Thanks for the info on Xraid, I did quite a bit of reading and it looks like that is what I will be using, it seems pretty easy to accomplish... Thanks for that information.
Have a great day.
- StephenBMar 21, 2016Guru - Experienced User
Bulk transfer is just transferring a lot of data. A backup job runs in the background, and can send you an email when it completes. So its a convenient way to copy a large folder to a share.
Again, I may be not asking the question correctly, so let me try ths one more time. IN a Bulk Transfer I would connect the External hard disk Drive I want to transfer the files from to the USB 3.0 port of the Netgear directly, then Drag and Drop the files from the External HDD to the Netgear. In this case I will not be using my computer for anythinng other than setting up the drag and drop from the External HDD to the Netgear.. I think you answered the question partially but please confirm that the drive is connected directly to the USB 3.0 port of the Netgear..
Thanks
