Retired_Member
Aug 31, 2017ReadyNas 202 - Connection cannot be established. Check the connection and authentication
Since the last four firmware updates my backups from a ftp server to the nas are failing after a while with Connection cannot be established. Check the connection and authentication serial number of ...
JennC
Sep 01, 2017NETGEAR Employee Retired
Hello philsbbs,
Is this local backup or over the Internet? Also, are you using the built-in Backup Job of ReadyNAS or a third party backup software?
Please post some screenshots of errors and settings.
Retired_Member
Sep 02, 2017Morning Jenn,
* It's a local backup and the nas is connected direct to the netgear switch, the ftp server is also plugged into the same netgear switch.
* I'm using the built in backup software in 6.8, also when the backup fails the Test Connection link still works.
Settings can be viewed via
https://readycloud.netgear.com/client/dllink.html#t=0i33glkx568/netgear.docx
Thanks for your help.
Have a good weekend.
Phil
- JennCSep 04, 2017NETGEAR Employee Retired
Hello philsbbs,
Are you using WAN/Internet IP address to point to the FTP server? If so, can you try using the LAN IP of the FTP server instead and see if there's any difference.
- Retired_MemberSep 05, 2017
Morning.
I've changed the server name to (local ip 192.168.x.y) and run the backup this morning and got:
Backup Job Name: current
Backup Job Type: Incremental
Protocol: ftp
Backup Source: [remote:ftp]/ftp://192.168.x.y/
Backup Destination: [Backups]/Current
Backup Start Time: Tue Sep 5 2017 8:56:29
Backup Finish Time: Tue Sep 5 2017 10:10:57
Backup Status: Fail: Connection cannot be established. Check the connection and authentication, if required.Failed to copy Excel_Files/sslimited/invoices/PS097.xlsx
Cannot connect to server or connection timeout! Timeout was reachedSome files did copy.
Once again I clicked on the test connection button in the settings and there was no issue test connecting to the ftp server and I can access the ftp via a ftp client with no trouble at all. I ran the backup yesterday and it toke like four attempts before one of the backups completed and the other backup just kept failing.
As I say I had no issues with the backups until about four firmwares ago.
Please advise what to do next.
- StephenBSep 05, 2017Guru - Experienced User
Have you tried a different backup protocol? for instance SMB ("windows") or rsync?
