Retired_Member
Aug 31, 2017ReadyNas 202 - Connection cannot be established. Check the connection and authentication
Since the last four firmware updates my backups from a ftp server to the nas are failing after a while with Connection cannot be established. Check the connection and authentication serial number of ...
Retired_Member
Sep 06, 2017The backup job that failed has completed from a manual start.
See what I mean its hit and miss if backup completes.
Retired_Member
Sep 08, 2017Morning All,
If I cannot find a solution shortly I will have no choice but to decommision the nas and purchase a synolgy or qnap solution.
So any ideas most welcomed.
- Retired_MemberSep 11, 2017
No change to report backups are still hit and miss.
On the good side my qnap has just arrived.
