whla
Dec 06, 2024Aspirant
ReadyNas 204 stuck at 99% boot
So I have gone through all of the links here I could find here and still no solution. I am stuck at 99% boot admin page will accept login but not load I am able to ssh into it Data will mount an...
Dec 06, 2024Guru - Experienced User
What firmware are you running?
I suspect the full OS partition might have corrupted the config files.
Is there anything else someone might recommend trying or is the only remaining step to do a factory reset?
There is a repair script you could try:
# cd //
# wget --no-check-certificate https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh/raw/master/share_lun_ui_fix.sh
# chmod +x ./share_lun_ui_fix.sh
# ./share_lun_ui_fix.sh
If that fails, the factory reset is probably the best step.
- whlaDec 06, 2024Aspirant
I am on 6.10.10
Thanks, I will give that script a shot.
