Jaroslaw's avatar
Feb 21, 2016
ReadyNAS 204 will not shutdown on schedule
Sorry to start similar subject to one about 104 but: ReadsyNAS 204 firmware 6.4.2 4 x 3TB Unit will not shutdown on scheduled times. I have to pull the plug and restart is possible only this way....
  • StephenB's avatar
    Mar 02, 2016
    Jaroslaw wrote:
    "Perhaps try a different bonding mode?"
    Hello which one would you suggest, please?
    First, Bonding only improves speeds when you have multiple users accessing the NAS simultaneously.  Even then, it doesn't always help, especially if you only have a couple of users. So my first suggestion is to turn bonding off altogether, and see if (a) the packet loss disappears and (b) you perceive any performance droppoff.
    The modes that make sense with your router are Adaptive Load Balancing and Transmit Load Balancing.  Ignore the other choices.  ALB operates in both directions (reading and writing), TLB only applies to reading.
ProSupport for Business
