Anonymous
Feb 07, 2023readynas 2100 3rf disk led power off
Hi, when I power on my used readynas 2100 the 3rd disk led is power off, instead the 1/2/4 disk led and power led are still power on. What's the problem? Thanks
Feb 07, 2023Guru - Experienced User
Retired_Member wrote:when I power on my used readynas 2100 the 3rd disk led is power off, instead the 1/2/4 disk led and power led are still power on.
Does the admin web ui show that the disk is operational? Or that the array is degraded?
Have you downloaded the log zip file, and looked in there?
Anonymous
Feb 07, 2023I can't access via web gui, I've already tried with the usb boot without any positive resolution.
- StephenBFeb 07, 2023Guru - Experienced User
What happens when you try?
- AnonymousFeb 07, 2023
Chrome says connection denied and raidradar no nas found =(
Do you know what firmware you are running?
Can you ping the NAS?
Is ssh enabled?
