gquickflora
Sep 25, 2015Follower
ReadyNAS 2100 Capacity
We have ReadyNAS 2100 rackmount. That currently have 4 disks of 1 TB each. I want to expend the capicity so can you tell us what is the maximum disk capicity i can install? I want to use 4 disks ...
mdgm-ntgr
Sep 25, 2015NETGEAR Employee Retired
Do you have the v1 or the v2? If you have the v2 it would say so in Frontview
3TB disks should work with either. I would stick to enterprise disks. Please note that if you use disks outside the compatibility list support may be unable to help.
The v2 should be similar to the Pro 4 in what disk capacities will work.
