flip3962
Nov 12, 2021Aspirant
ReadyNas 212 Firmware Download
My FirmWare is 6.10.5 Hotfix 1. I believe the latest version is 6.10.6, but when I click Check For Updates it comes back and says I have latest version. When I click on Cloud tab, it says Internet Av...
- Nov 12, 2021
I found the product data sheet. ARM
flip3962
Nov 13, 2021Aspirant
tried to update and get popup box with big red X and "Unrecognized Server Error" no error code or other information. Nothing in the log
Nov 13, 2021Guru - Experienced User
Try rebooting the NAS anyway, and see if it installs anyway. This has happened before, and the NAS usually had downloaded the firmware file (despite the error).
If that doesn't work, then try again (you likely will still see the unrecognized server error). Hit cancel if you see it, and once again try rebooting anyway.
