shardie
Jun 03, 2018Aspirant
ReadyNAS 2120 runs cooler with custom fan - less noise too.
If there is one thing I hate about servers, its the noise from the fans. So, I decided to pop the lid off and install a custom fan. I dissabled the internal small fans. I compared the temeratures and...
Frank888
Jun 04, 2018NETGEAR Expert
Hi Shardie,
Could you share the FAN brand and model #?
we can consider as the solution of next generation.
Cheers
Frank
shardie
Jun 04, 2018Aspirant
The fan is a Cool Master. You can use any quiet PC fan.
Lower temps and very quiet.
- shardieJun 04, 2018Aspirant
Ive also made a custom steel frame for the NAS's - its more open for better airflow.
- StephenBJun 04, 2018Guru - Experienced User
Note that hardware changes can void the warranty (with desktop ReadyNAS, simply opening the case voids the warranty).
Apparently the warranty is not transferable - Im not the original buyer of the unit, so the warranty doesnt really make any difference any more.
- Nov 30, 2019Retired_Member
