shardie
Jun 03, 2018Aspirant
ReadyNAS 2120 runs cooler with custom fan - less noise too.
If there is one thing I hate about servers, its the noise from the fans. So, I decided to pop the lid off and install a custom fan. I dissabled the internal small fans. I compared the temeratures and...
Jun 04, 2018Guru - Experienced User
Note that hardware changes can void the warranty (with desktop ReadyNAS, simply opening the case voids the warranty).
shardie
Jun 04, 2018Aspirant
Apparently the warranty is not transferable - Im not the original buyer of the unit, so the warranty doesnt really make any difference any more.
- StephenBJun 04, 2018Guru - Experienced User
That's true. I added that caveat so others reading your post won't inadvertantly void their warranty making similar mods (which has happened sometimes).
FWIW, I replaced the system fan in my older ReadyNAS Pro-6 yesterday (and earlier needed to upgrade the RAM). I'll probably replace the CPU fan soon. It's also out of warranty.
- Nov 30, 2019Retired_Member
