RC001
Nov 30, 2015Aspirant
ReadyNAS 2120 v2 hangs after changing USB 3.0 harddrive
Hello, we have a problem with our "ReadyNAS 2120 v2". Every day when we connect our USB 3.0 portable hard drive for backup on our ReadyNAS, the ReadyNAS hangs up and we have no access to the Read...
mdgm-ntgr
Nov 30, 2015NETGEAR Employee Retired
Which firmware are you running and what model portable USB3 disk?
Have you tried putting an AC powered USB3 hub between the NAS and the USB disk?
Do you have any open/past support case numbers that I could look at to review the history of the problem?
Are you able to send in your logs (see the Sending Logs link in my sig) if they are not already attached to an open support case?
The ReadyNAS 2120 v2 has a more powerful CPU than the ReadyNAS 2120.
- RC001Nov 30, 2015Aspirant
Hello,
thank you for your fast answer! Below I will answer your questions:
Firmware: Ready NAS OS 6.4.0
USB 3.0 Disk: Western Digital My Passport 0740 and the successor model.
Have you tried putting an AC powered USB3 hub between the NAS and the USB disk?No.
Do you have any open/past support case numbers that I could look at to review the history of the problem?Yes. Number: 25897331, RMA: #1593537
I sent you the Log Files. Last hang up was on 27th Nov 2015. You see the changed serial number, too. (because of replacement)
Hello,
I sent you a more recent version of the log files since the last hang up was a few minutes ago.
- mdgm-ntgrNov 30, 2015NETGEAR Employee Retired
One of the disks in your NAS has a rapidly rising reallocated sector count. Have you considered that this disk might be the problem?
