aks-2
Aug 26, 2023Apprentice
ReadyNAS 214 data corruption issue
I am seeing a very strange behaviour that results in corrupted files. My NAS (ReadyNAS 214) has been stable for years, until recently I found a single file had an error revealed via the logs followin...
Aug 26, 2023Guru - Experienced User
aks-2 wrote:
Aug 26 17:54:53 NETDISK kernel: BTRFS error (device md124): bdev /dev/md127 errs: wr 95, rd 333, flush 0, corrupt 0, gen 0
Which of course looks bad, and is probably why I am getting corrupted files.
Are you also seeing disk errors? Or just btrfs errors on the RAID array?
aks-2
No disk errors in the logs, or reported in the dashboard logs page.
- StephenBAug 26, 2023Guru - Experienced User
Have you run the disk test from the volume settings wheel lately?
One option is to do a factory reset (or destroy/recreate the volume), and see if the sync succeeds. Are you using X-RAID? Or FlexRAID with multiple volumes.
- aks-2Aug 26, 2023Apprentice
Recent maintenance has been:
- scrub (two weeks ago)
- disk test (two weeks ago)
- firmware upgrade to 6.10.9 (last week)
- defragmentation (last week)
I am using X-RAID, with 4TB + 4TB + 8TB + 8TB, and been stable for a very long time.
I wondered if the firmware upgrade and/or defragmentation might be the cause, but I observe others (including yourself) at least using 6.10.9.
aks-2 wrote:I am using X-RAID, with 4TB + 4TB + 8TB + 8TB, and been stable for a very long time.
Errors on md124 suggest that you've vertically expanded the volume at least 3 times (md124, md125, md126, and md127 all exist).
Normally I'd expect disk errors to go along with the btrfs errors.
How much free space to you have on the volume?
I have several ReadyNAS running 6.10.9, and haven't seen any signs of BTRFS problems.
