Bigmaca
Mar 08, 2019Aspirant
ReadyNAS 214 Not Booting
This morning I need to unplug my ReadyNAS 214 via the mains plug socket. Before doing so I powered it off using the power button on the unit. I unplugged it from the mains, added the plug to an adapt...
Bigmaca
Hi JohnCM_S,
Thanks for your help with this.
I can't I don't think as it says the unit is booting and nothing more. How could I grab the logs through Raidair?
Can I run it in safe mode by using the reset button on the back?
Would reinstalling the OS help with anything? And would it delete anything as well?
JohnCM_S
Mar 08, 2019NETGEAR Employee Retired
Hi Bigmaca,
You will not be able to run the NAS in safe mode using the reset button. Safe mode will appear when the NAS encounters the situations listed in this article.
OS re-install should not delete any data on your NAS but I don't think that it will be much of help on this situation. Perhaps try first booting the NAS to read-only mode and see if you can access the data on that mode.
- BigmacaMar 08, 2019Aspirant
Hi JohnCM_S,
When I'm home I'll give this ago straight away. If I am able to see the volumes in safe mode, but from memory it will not give me that function as everything seems to be working normally and it isn't displaying an error.
I think this has happened before and then after multiple attempts it came back on. I won't bother with the OS reinstall
- BigmacaMar 09, 2019Aspirant
Hi JohnCM_S.
I've been trying all evening to sort this but had no joy. There is no way for me to get the logs on Raidar or on admin page as I can't get onto either as it says that the unit is booting.
In Raidar is shows all volumes with a tick so I guess they are in working order. If it's any help the unit gets to an xagent.service which takes ahwile to boot and then gets stuck on upnphttpd.service at 99%. Is there anyway around this, I'm now petrified I'll lose data. I can't boot the unit into safe mode either. If I take out the disks it will but there are no logs to take.
Thanks for your help with this, I really hope we can sort it. I've left it unplugged over night so fingers crossed
- StephenBMar 09, 2019Guru - Experienced User
That isn't possible. The system will automatically boot in safe mode in some circumstances. But there is no manual way to do that.
What you could attempt to do is boot the system in read-only mode (not the same as safe mode). Is that what you tried?
If read-only mode doesn't boot, then I suggest contacting paid support for this.
The only way to avoid data loss is to have backups. RAID isn't enough.
That said, I think the odds of paid support getting your NAS to boot w/o data loss are good. After that you should put a backup plan in place for your data.
- JohnCM_SMar 09, 2019NETGEAR Employee Retired
Hi Bigmaca,
Just in case that you need it, here is the link for the steps on how to boot the NAS to read-only mode. If you cannot still access your data on that mode, it will be best for you to try the NETGEAR paid support as what @StephenB has mentioned.
