SameerVashisth
Nov 04, 2017Follower
ReadyNAS 214 Read Write permission on Centos 7
Hello,
I am having a ReadyNAS 214, have created a share using NFS. I am using a PHP application to save and read photos from NAS. When I mount the partion it shows only read permission. How to fix this issue so I can read and write at the same time.
Thanks
Sameer
- JohnCM_SNETGEAR Employee Retired
Hi SameerVashisth,
Welcome to the Community!
I understand that you want to have a read and write access to a share folder using NFS. Please check first if the read/write is enabled under NFS for that folder. You may check that by going in to share folder settings then go to the Network access tab and then go NFS.
JohnCM_S
NETGEAR Community Team
Hi SameerVashisth,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards,JohnCM_S
