Luigi-Network
Aug 05, 2025Aspirant
ReadyNAS 214 turns itself on - after a power outage.
I have several ReadyNAS devices running the latest firmware version 6.10.10 (214, 104, 312, etc.). I was able to configure all of them so that, after a proper shutdown and subsequent power off, they ...
Luigi-Network
I've already tried a factory reset and also disabled WOL. The settings are completely identical to those of my other ReadyNAS 214. Is there anything in the hardware that can be adjusted? I bought the ReadyNAS used. Perhaps the previous model had some adjustments...
- StephenBAug 05, 2025Guru - Experienced User
Not that I know of.
Some ReadyNAS have VGA headers on the system board. With those systems, you can connect that to a VGA monitor and hook up a USB keyboard. Then you can see the BIOS. But I don't think the RN214 has that header.
