PerlDiver
Jun 17, 2023Aspirant
ReadyNAS 214 won't recognize replaced drive
RN214 I've had for a number of years had its first disk issues: lots of ATA errors for disk 4 and "degraded" status for the RAID-5 volume. I bought two new drives from Newegg (Toshiba DT01ACA200, sam...
PerlDiver
Jun 20, 2023Aspirant
Thank you! I will try this and report back.
PerlDiver
Jun 29, 2023Aspirant
I'm unable to find my SATA cable (it's a moving box somewhere) but both drives fail the "try it alone in slot 1" test. After the RN214 boots and gets on the network, the admin UI shows "no drives detected". I'm going to return both drives to NewEgg.
I found this post about choosing replacement drives. It applies to a "voluntary" replacement; in your opinion, would one of the recommended drives (8TB WD "Red" or Seagate "Ironwolf") also be suitable for replacing a failing drive?
Thanks so much for your help!
- StephenBJun 30, 2023Guru - Experienced User
One of my old posts.
WD branding has changed - WD "Red" drives are now all SMR, which I do NOT recommend. WD Red Plus and Ironwolf are both good choices for the RN214. I generally purchase on of those drives for my own NAS (and pick whatever seems cheaper at the moment). At the moment, Amazon has the Seagates for a bit less.
Either way, I'd go with 2x8 TB instead of 4x2 TB. That gives you 2 TB more capacity than you had before, plus two empty slots for expansion later on.
- PerlDiverJun 30, 2023Aspirant
Damn, I jumped the gun and already ordered a WD Red Pro (not Plus) WD8003FFBX 8TB. Is that one going to cause me grief?
- StephenBJul 01, 2023Guru - Experienced User
It's fine. The Red Pro are enterprise class drives and don't use SMR. Ironwolf and Red Plus are cheaper, so I generally recommend them for desktop NAS. But enterprise drives are also good choices.
