TonyArgh
Aug 20, 2024Aspirant
ReadyNAS 2304 AV hasn't updated in months
Is it because my NAS is EOL? And if so, can I stop it from checking for updates every 3 minutes? If this isn't the reason and I can still get updates, is there something else I can do? I did see an...
Aug 20, 2024Guru - Experienced User
what firmware are you running?
- TonyArghAug 20, 2024Aspirant
6.10.1
Disabled AV for now.
Will reboot appliance this evening when my last end user leaves (around 8PM EST).
Will reenable it then and report back.
- StephenBAug 20, 2024Guru - Experienced User
TonyArgh wrote:
6.10.1
There's several AV fixes you are missing in 6.10.5 and 6.10.6, and 6.10.8
- ClamAV fails to update database.
- Antivirus ClamAV is upgraded to version 0.103.2+dfsg.
- Updates anti-virus ClamAV to v0.103.7
If you've installed apps, or have uploaded packages to the NAS web ui, then I recommend upgrading to 6.10.9
If you haven't done that, then I suggest upgrading to 6.10.10
