DaveSh
Sep 09, 2015Tutor
ReadyNAS 312 Frozen on disc replacement
Hi! I had a failed disc on the unit so decided to replace both with same size 3TB WD red drives. Replaced the first following the standard procedure. No problems, left it for a day to ensure all was ...
- Sep 11, 2015
Not as far as I know.
Some users report problems with the DM disks. Perhaps test that disk too.
Did the resync only take 1 hour with all the disks you tried?
vandermerwe
Sep 11, 2015Master
DaveSh
Sep 15, 2015Tutor
Hi vandermerwe,
Yes the resync was fast on all discs. I just didn't stop to calculate whether it was feasible at the time. I completed a full scan on one of the new WD discs which turned up no errors, and will test the DM disc when I have time. Just very busy catching up with work at the moment. Thanks very much for your help.
- vandermerweSep 15, 2015Master
Have a look at this
