mistercatworks
Mar 06, 2017Aspirant
ReadyNAS 312 vertical expansion but capacity not shown increased
Peformed vertical expansion: replaced first 4GB drive with 8GB, waited until "degraded" changed to "healthy". Replaced second 4GB drive with 8GB, waited until "degraded" changed to "healthy" Unf...
- Mar 06, 2017
mistercatworks wrote:
Unfortunately, on system status page Capacity still shows as 3.63TB and has not increased.
How to I tell the system it has greater capacity?
Sometimes it takes a while for the expansion to complete. If it still says 3.63 TB now, try a reboot.
When did you purchase your RN312? If you purchased it new between 1 June 2014 and 31 May 2016, then you have lifetime chat support via my.netgear.com.
Mar 06, 2017Guru - Experienced User
- mistercatworksMar 06, 2017Aspirant
It's been several days. I'll try a reboot as soon as that is convenient.
After two restarts, the ReadyNAS 312 still shows only 3.63TB capacity (instead of nearly 8TB, the way it should) and the "free space" value is the same as before the drives were replaced.
What else can I do?
- StephenBMar 06, 2017Guru - Experienced User
Start by answering this.
This ReadyNAS 312 was purchased February 2014, although we did purchase a ReadyNAS 516 in July 2014, which will soon need a similar vertical expansion.
I marked the wrong answer as solution.
fixed.
