mistercatworks
Mar 06, 2017Aspirant
ReadyNAS 312 vertical expansion but capacity not shown increased
Peformed vertical expansion: replaced first 4GB drive with 8GB, waited until "degraded" changed to "healthy". Replaced second 4GB drive with 8GB, waited until "degraded" changed to "healthy" Unf...
- Mar 06, 2017
mistercatworks wrote:
Unfortunately, on system status page Capacity still shows as 3.63TB and has not increased.
How to I tell the system it has greater capacity?
Sometimes it takes a while for the expansion to complete. If it still says 3.63 TB now, try a reboot.
When did you purchase your RN312? If you purchased it new between 1 June 2014 and 31 May 2016, then you have lifetime chat support via my.netgear.com.
mistercatworks
I marked the wrong answer as solution.
Mar 06, 2017Guru - Experienced User
fixed.
